Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Touch Id sensor snapped off
Hello
I drop my iphone 5s and the touch id sensor itself fell off.
I know the touch id only works with this phone so replacing it won't give me touch id back. I have read somewhere that someone can re solder it so you can you use it again.
Does anyone know how this works,
Thanks
Is dit een goede vraag?
Score 1
1 Opmerking
Hello! did you find any one? i have a same issue. Id sensor cable snapped
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You are right about the Touch ID not working if you replace the home button. You'll be able to use it as a home button but it won't read your fingerprints anymore.
What you say about someone re-soldering it is true as well. Anything that can be done once (1st time was in the factory) can be done again. It does depend on where the Touch ID snapped off though. You'll have to find someone who is good enough at micro soldering to do this, and most of your local repair shops won't solder let alone do advanced soldering like that. Check and see If any of the flex cables are ripped though. If they are you're basically out of luck and will need a new home button.
I know this isn't the best new but I hoped it helped. Good luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Lukas Guy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 481
