Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Three ghost white lines after digitizer replacement?
Hi There. I just did my first ever digitizer replacement on a friend's iPad mini with retina display. The swap out went pretty good as far as I could tell but when I reassembled the device, there were three ghosted white lines vertically down the middle of the screen. They are each abuot a quarter inch thick and they are see through, but noticeable. I was very careful not to trap and glass shards or flecks from the cracked digitizer. I also did not use excessive heat. The only thing I may have done wrong was when removing the LCD, I was separating some of the black tape that holds the lcd close to the antennas on wither side of the home button. I may have exposed some copper traces along the edge of the lcd. To be honest, I don't even know if that makes sense. I'm not an electronics wiz and I apologize for not knowing the terminology. The edge of the lcd... I scraped away a small amount of the black coating, and I believe there was some copper exposed. I could be overreacting to that, but I cant think of another thing I may have done wrong.
Maybe I alternated one or two of the four screws that hold down the lcd. I know I got every other screw exactly right, but except for the lcd corner screw next to the rear facing camera (Which I know I replaced properly, I may have alternated one or two of the others.
Beyond the lines, the iPad mini works perfectly.
Oh.. I also did not replace one of the small magnetic spacers in the corner. I had watched many videos and hadn't seen anyone mention those. It was an oversight.
If need be I can open the device up again and replace the lcd and the digitizer again (since I am sure I'll break it opening the thing), but I don't want to do that if the lcd is not the problem.
Sorry for the confusing post. Again, I don't know all the proper terminology.
Thanks in advance for any help.
Any clue as to what may have gone wrong?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
I had a single quarter inch horizontal line that looked like opaque plastic. I took off the digitiser and it was 'goo' stuck to the inside of the screen. Some careful cleaning and reassembly and it's all good.
Was dit antwoord nuttig?
Voeg je antwoord toe
Dan Cook zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 656
