Ga door naar hoofdinhoud
Monitor does not light up?
I can hear the startup chime when I turn it on and the light left of the lock release it on solid white when I turn it on. I can hear the chime when I tap the volume keys. I've tried using an external monitor with no luck but I think that has to be selected from my laptop. What else can I do to determine what needs to be replaced? Could it be my video card?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Your best bet is the Nvida GPU issue to get a new logic board. See the link to this question then click on the Contact Center link.
Failed GPU Apple Program or Other Repair
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
It is possible that your particular computer falls in the batch of defective video card MacBook Pros. Here's the KB article describing it and what you can do: http://support.apple.com/kb/ts2377
I suggest taking it to an apple store with this information in hand, and they should be able to run a quick test to see if that's the problem. You'll notice that even if it's outside of the warranty period, they will still cover the repair for up to 4 years after the purchase date if this is the source of your problem.
Score 2
4 opmerkingen:
+ Good answer, looks like we were typing the same answer at the same time.
door
yeah same to you. I became a ACMT recently for my university so we could repair all our own apple computers and I've already seen this twice on the 15 inch MBP core 2 duos. Seems to be somewhat common actually.
door
I've sent in 3 in the last month and a half.
door
Thank you so much for your answer. I just called for an appointment to get it repaired. I mentioned the article about my laptop being in this batch of defective video cards.
door
2 screens only large screen will light up
the screen on my laptop will not come on when i connect to a larger screen
i have two laptops one is a acer and the other one is a hp. and the monators will not lite up. i tried putting up to the light to see if i can still see any kind of inprint on the monators it looks like i can see microsoft. but i`m not sure my sight not so good
Voeg je antwoord toe
TOMAS VASQUEZ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,000
