Test LCD screen on 6+, glass repair
Im in the middle of a 6 plus screen repair, I'm attempting to replace just the glass only and lucky enough I've been able to remove the glass without any damage to the screen.
Well I'm not sure yet, I'm trying to test the lcd, I've connected both connectors from the lcd to the logic board and pressing the power button is doing nothing.
I'm thinking my battery may be dead, I'm just wondering if its safe to charge it without display connected...?
Is dit een goede vraag?
2 opmerkingen
I have a full display assembly lined up in case I need to replace
It actually comes with all parts, camera, shield plate and home button.
Now it's only the home button I need to replace, the flex cable is ok, yeah?? And should I replace the camera will the original be better quality...
door Aidan
I would install the new assembly as is. Especially if you're still feeling your way around the repair process. Simply because there is too uch that can happen by removing an already installed component like getting oils on grounding points or contacts & when frustration starts mounting its time for a break. Get the repair done, high five yourself and come out on the positive. Good Luck
door South30
