Ga door naar hoofdinhoud
The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
78 Vragen Bekijk alle
Digitizer not responding after replacement.
I replaced the LCD and digitizer on my 2014 Moto G and now the digitizer will not respond to any touch. I can still use the power and volume buttons and the screen turns on but I can't do anything else with it.
Any ideas what it could be?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
try to watch the phone repair video from witriggs! maybee you see some mystakes, it could also be that you didnt fully push the screen connector into place
Was dit antwoord nuttig?
I would second grindfi, definitely make sure that all your connections are tight. Don't force anything! Also, did you check the connector on the motherboard to make sure it did not get damaged?
Voeg je antwoord toe
Darren Landis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 594
