Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Why wont the LCD cable stay in?
Hi, I am replacing the screen and home button on my iPhone 4. The LCD cable is long enough to go in its socket, and looks like it should fit, but it does not pop in, and keeps sticking straight upwards. Any thoughts ?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Remove the rubber bumper from the top of logic board, it may not be installed correctly. Fold the flex cable properly, many have the dotted lines where it should be folded.
Was dit antwoord nuttig?
1 Opmerking:
It turned out that the cables weren't folded properly. In the end I also had to use more force that I thought to get the cable to go in, but now all is well and iPhone is fixed.
door
Also make sure that both cables are pulled through all the way and aren't pinched between the lcd and chassis.
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 44
