adjusting deck height riding mower
mower has 6 height settings. it is cutting too short. how is deck height adjusted? 16 hp 42" cut 6 speed trans.
Is dit een goede vraag?
Annuleer
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkelpush the button on the long handle on your right and slide forward or back toward you to adjust cutting deck height
Commentaar:
Even using the lever the deck has no height I have the same problem on my kgro
I have the same tractor. There are adjustable rods at the front that adjust height but not too much or the back of the deck is lower.
door Terry Raymond
Rep: 1
size oil for kgro power pro 18 hp 42 cut
Rep: 1
Adjusting the rods at the front helps but not too much of the back of the deck is too low.
I have to replace the blade drive belt so more head scratching to figure this out.
Pulling the deck off is a pain In the tush.
hope my suggestion helps.
I have the same tractor, it runs and all but the deck won't turn the blades. Does it need adjustment and how do you do it? Thank you.
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 7
Altijd: 2,554
