Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Some problems after Battery replace
Hi,
I have changed my battery and i have a lot of problem...
First i have change the battery and i have a problem, the Touch Id doesn't work.
In Settings when i want to activate it, it's written "Fail".
I don't know why, because i have desassembly the phone without problem..
Few days later, i need to charged 3/4 times my iPhone per day and it's a new Battery ( very good quality buy here) and my External Speaker Doesn't Work...
What can i do ?
Is dit een goede vraag?
Score 3
1 Opmerking
Have you tried to restore from itunes?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You may have accidentally damaged some components during installation. Have you inspected the ribbon cables to see if there is any damage? It's always a good idea to go back through and make sure all the connections are clean and fully seated. You can clean them with isopropyl alcohol on a cotton swab, and make sure they're completely dry before you close up the phone again.
Does the home button click function still work?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yes the home button Work, just the Touch ID and the external speaker doesn't work..
door
Download a programme on laptop called ibackup bot it will actually tell you how many times the battery has been charged..
Most new batterys you get are never original and have been charged I've 100 times unless you have a good supplier
Score 1
I had the same problem, found sensor cable was not seated fully. Took quiet a few goes to get it right.
Voeg je antwoord toe
robinphi58 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 274
