Ga door naar hoofdinhoud
BlackBerry's newest flagship that features a physical keyboard.
73 Vragen Bekijk alle
Can blackberry passport water damage be fixed?
My blackberry passport fell inside water. i picked it and dried it and it worked for about a week till it suddenly went off and won't power up again.
I've taken it to the repair and i'm told i need to change the panel which is unavailable in the Nigerian market. please where can i get the panel. also will it be possible to fix this phone
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
No change for main board needed ask technician to remove ( brake ) one rectangular resistor between battery connector and display connector. If phone have water inside this resistor change and drain battery to 0 and prevent charge. I do same on may Passport and it working after one minute charging.
Was dit antwoord nuttig?
yes its possible the phone will work, what ill like you to do is to contact me or watsap me on 08030732622,you be happy you did
1 Opmerking:
hi chucks kindly sendme a watsap message on my contact,im based in Abuja we will discuss how in get the phone for repair
door
Voeg je antwoord toe
chukseboagwu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 1,828
