Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
20 Vragen Bekijk alle
Battery not charging at all
Ok welll i have problems with my battery charging, i have done a SMC reset, test with differents power adapter and got 2 new battery because i though they where dead. But when the new battery came it works just fine and it read that it had 50% charge and all, but the next they the computer battery was dead and it was with the power adapter and now it wont charge and as i said i have reset the SMC
Is dit een goede vraag?
Score 6
1 Opmerking
Hi was my answer helpful? do you need any more help?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Check R7051 & R7052, as well as R7021 & R7022. I mean with a multimeter, when these blow they often look perfect. Further, see if the magsafe light turns orange when the laptop is off.
Was dit antwoord nuttig?
Score 3
Something like this are most likely cause by fake aftermarket chargers or liquid damage.
Can you inspect the chip i highlighted to see if it is any burn marks or corrosion?
Score 1
Voeg je antwoord toe
siul2893 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 935
