Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
iPhone keeps losing service after I dropped it
I dropped my iPhone 3g the other day. Now it keeps losing service off and on sometimes it gets service and I can get text messages and make calls, but then loses service in like 30 seconds even though I haven't moved it. My phone is also jail-broken for t-mobile.
Please help me out; my wife is super mad because I just got this phone after I broke my other one.
(This is a question asked by Steven from our discussion forums that did not get an answer. We'll see if you guys can help!)
Is dit een goede vraag?
Score 3
1 Opmerking
I have 3g 16gb iPhone. I can hear from the phone the speaker and headphone works. all other functions works.
door
Voeg een opmerking toe
13 Antwoorden
Gekozen oplossing
Sounds like a loose connection for the antenna.
Was dit antwoord nuttig?
Score 5
Every time you lose service, a much faster way to get service is to turn airplane mode on and off. Also, have you updated your iPhone to the latest software? If you haven't you should do it. And if all this does not work, try restoring your iPhone and get it swapped out at the genius bar. But don't tell them you dropped it. They have no way to find out! Also un-jail break your phone before you take it there.
Score 2
The problem is a loose cable. Open the iPhone through iFixit steps and reconnect the cables and you are fine.
I have fixed a lot of phones this way with the same problem.
Score 2
2 opmerkingen:
Remember kids, good spelling and grammer saves lives.
door
Ironic. You misspelled grammar. Maybe you should fix yours.
door
Depending on your current firmware, updates also update the radio's baseband. I was having the same problem for a while until i did a full update. Carriers will always change their network configurations to increase their data speed. Also before you do so, back up your files and do a complete reset all settings from settings/general/reset all settings. It will take about an hour. This will erase any registry file value that could be causing the issue. Hope this helps.
Score 2
When you dropped your phone i think you have damaged your mother board. I had an incident with my iPhone 3G and now it will only pick up 3G signal. Take it to an Apple store and see if they will replace it for you. I don't think there would a DIY solution for this.
Score 1
I had the same problem and had to replace the antenna and antenna flex.
It takes a lot of patience to do it, but it works fine now!
total cost: €20 (or 30 dollar something)
Score 1
This may sound strange, but I believe if the SIM isn't seated properly this can occur also. I think it's much more likely the antenna is damaged though, the flex cable is delicate.
Score 1
Hate to state the obvious, but have you tried a reboot?
2 opmerkingen:
I think you can't comment until you have 30 reputation, but in the future this would be better as a comment instead of an answer.
door
You still need to understand Nate, the major difference between learning how to spell “grammar,” and misspelling it and calling out on people when you yourself can’t spell it right.
door
My phone is having the same problem, i lose service all the time and its in the open where i always get service. i try to reboot and it doesnt work, reset the network settings and it doesn't work, turn it on airplane mode and it doesn't work. and then sometimes it doesn't lose service for hours. what do i do?
1 Opmerking:
I have bought iPhone 6plus n used for one month after that it has lost service.I tried many means n ways but still no network. But inside when I check cellular is active...
Any body help me to solve the problem....
door
I have exactly the same problem with CAM. i ever dropped my iPhone :- and then the problem happened.
I have the seame problem of "No Service"...... It has been sent to a repair center and they have said that the charger socket is damaged and so the repair is not covered by warranty...... There is no problem with charging or conecting to iTunes, is it possible for a damaged charging socket to cause "No Service"??
1 Opmerking:
Dock or "charging socket" has the antenna on the underside of this plastic piece. It is cheap and easy to replace the entire dock connector which includes mic/speaker/charging socket and the antenna. Follow repair guide for dock in upper right of this page. Please start your own question too!!!
door
If i was u just replace the antenna or put a foil on it that covers the battery and the signal well give it a big boost and it shouldnt be cut off anymore. That's what did and it's works good :)
my iphone 3g 16g just have an apple logo when i started up.. just that.. why???
what must i fixed??
Voeg je antwoord toe
Kyle Wiens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 40,329
