replacing the HDD with an SSD
Is it possible to replace the HDD with an SSD on my HP G71?
Is dit een goede vraag?
Yes you can.
You'll get some performance improvement after SSD replacement as the systems CPU & memory will limit you. You will gain more run time using the laptop in battery mode, than running with a HDD.
Modern SSD's come with auto sensing SATA III (6.0 Gb/s) interfaces. Your systems chip set only supports SATA I (1.5 Gb/s). The SSD will sense this and run at SATA I (1.5 Gb/s) speed.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 782
