Ga door naar hoofdinhoud
The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
What parts do I need for my dell dimension to boot up
Computer doesn't boot and this is the screen in setup. I know i need something so does it matter the brand or model?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
fault is your Hard disk is not detecting by the bios.
1) Check the IDE cable
2) Clean the IDE connectors
3) Check the jumper status : keep it master if no other device connect to the same cable
4) change the port if above 1-3 steps not work
5) Update the BIOS if above 1-4 steps not work
6) run diagnostic on motherboard related to IO / check the south bridge works find
Cheers!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
yes the hard disk is not detected but it could be a bad hard disk
door
Voeg je antwoord toe
sara zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 689
