Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Vraag afgerond
Maximum RAM with SSD upgrade?
If I upgrade my current hard drive to a 1T SSD for my mid 2012 Unibody MBP, does that mean my computer can take a higher maximum RAM or is it still 8GB between the two slots? I also read that unofficially MBPs can take up to 32 GB, does the hard drive affect this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There is no direct dependency between the HD storage and RAM memory. You can alter one without altering the other.
Before you do either what don't you tell us why you think you need more storage or RAM.
Was dit antwoord nuttig?
Score 2
Actually as it was said before, both are unrelated.
You can top the RAM to 16Gb (I own an MBP13 Mid 2012) and it will take most of the things you throw at it effortlessly.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 156
