Ga door naar hoofdinhoud
The HP Compaq 6710b was released in 2007. It is a 15.4-inch widescreen business laptop for professionals, students, and users. It features a sturdy construction and a lasting battery life.
How can I stop my computer from overheating?
When I am using my laptop, sometimes it becomes really hot to the touch on the back of the laptop.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You can open your laptop and clean the dust out of it. Also you can reapply the thermal paste to the cpu. Make sure you clean your old paste off. Use a coffee filter to clean it off. That should make it run a little cooler.
Aanbrengen van koelpasta
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Also use your laptop on a hard surface not your lap!
door
First, try moving your computer to a flat surface to make sure the ventilation is not blocked. If that does not work, you should clean the internal fan, this will require some disassembly. The last thing you could try is replacing the heatsink thermal paste.
Score 1
Voeg je antwoord toe
Khulan Orgil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 880
