Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
I need more than 8GB
When I purchased this FIRST Retina MacBook Pro, I waited over 6 weeks. I ordered the 8 GB RAM model, which is the first MacBook to have soldered in RAM.
No one even mentioned that to me as everyone was so excited about the Retina screen. Now Apple makes the 15" model with 16GB RAM as a standard.
No 8GB models are made anymore.
I need more than 8GB since updating to the latest version of Yosemite 10.10.3.
I feel Apple should have let me know about the RAM not being upgradable.
I've been using Apple products since1986. That's 29 years of many, many products.
They should do something for me, as I've been a loyal customer and am on disability, so
Is dit een goede vraag?
1 Opmerking
I can't even afford a newer model.
Any suggestions
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@Brian - Nothing you can do to increase the RAM it is what it is. But you are likely hitting a different problem here which makes you think you need more RAM when you really don't!
You see, your SSD is also used for Virtual RAM! So when your SSD has too little room left it will slllooowww dooowwwnnn your system!
OK, how to fix...
The first thing here is to do a good housecleaning getting rid of any old junk you just don't need. Here is a good housecleaning app to flush-out old log & cache files Disk Doctor
You may want to consider deleting your iTunes Movie and TV shows (or your music if you have a lot). You'll need to have iMatch services enabled so you can stream them from Apple when you want them over the network.
The goal is to leave 1/4 to 1/3 of the SSD free, If you really can't get to this its time to get a bigger SSD. Here's one source: Transcend JetDrive 725.
Lastly, I would also recommend you get an external drive to hold anything big and/or important (copy). If you can't swing the upgrading of your SSD right now. Besides if you set it up as a bootable drive you can use it to help maintain your internal drive with Disk Utility.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Brian A Marder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 132
