Ga door naar hoofdinhoud
Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
16 Vragen Bekijk alle
Why is my camera not turing on?
I keep using the power switch and the camera won't turn on. The screen is black and not making any sounds, what should I do?
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hi John,
There are a couple things that might be wrong. The first thing that I suggest doing is replacing the batteries. If you do that and the camera still does not turn on, you may have to replace the power switch. Check here for more information.
Hope this helps!
Was dit antwoord nuttig?
Score 1
The lense won't extend. And tells me turn back on.
I had a battery leak in the battery compartment how can i repair my s2500hd camera?
Voeg je antwoord toe
John Kemmitt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,855
