Ga door naar hoofdinhoud
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
Will Charge but No Data Connection
OK, so here is the problem - The lightening Port was corroded I cleaned it thoroughly it now charges but no data connection to computer or car. Tried new cable and no change tried another ipod (same style) and it worked fine. Could this be a software issue or the port needing to be replaced
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Sorry it's a bit late, but I randomly came across this and noticed no replies. You've probably replaced the device or something by now, but just to answer your question, it was most likely the lightning port needing replacing if the same cable worked on another device. You could have tried to clean it some more but if it's corroded, that was probably the issue. :)
Was dit antwoord nuttig?
Voeg je antwoord toe
Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 108
