Why won't my camera turn on?
When I press the power button, nothing happens.
Is dit een goede vraag?
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
Was dit antwoord nuttig?
I have a Samsung St77 and when I charge it with the battery inside using a usb it just blinks red light and it means that it has an error, how do I fix this?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 1,050
1 Opmerking
Mine fell down and the lens never eject
door S`busiso mqapheli
