Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
8 GB RAM with 2 GB RAM in both slots?
I removed the old 2-2GB RAM cards and put one 8GB card back in, leaving one slot empty. Can I re-install one of the old 2 GB RAM cards to create 10GB of RAM, or does it not work that way?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Can the laptop handle more than 8GB RAM? The question has been asked before such as here and the short answer is YES: you can install up to 2*8GB RAM in this particular model.
Do you need more than 8GB RAM? Probably not, and that's just my experience: this model has a mildly fast i5 and a standard 5400 rpm HDD. If you want to spend more money on upgrades, get an SSD.
Can we install 8GB+2GB RAM? Yes we can, although ideally the 2 channels better have the same RAM installed. In other words, the laptop will perform better if you install 2*4GB instead of 8GB+0GB.
You have an empty slot and a 2GB RAM stick, should you install it? You can do that and test your laptop. If you experience any incompatibility issues (the laptop will freeze/act-out/not-start, etc.), you can take it back out.
Would I bother? No, if I had your current configuration, I wouldn't bother with those additional 2GB RAM, but that's just a personal opinion.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Charlie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 4,936
