Ga door naar hoofdinhoud
De Galaxy S Duos is herkenbaar aan het modelnummer S7562 en is een smartphone met dual sim-kaart van Samsung.
My touch screen is not working
my samsung galaxy s duos touch not working what shall i do ?
Is dit een goede vraag?
Score 4
1 Opmerking
did it stop responding after a drop or were you just using it and it stopped?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would do the following before considering a screen replacement.
  • Restart the phone
  • Inspect the cable, the cable should be accessible without unscrewing the back. Remove the back case and on the upper left corner you will see a plastic piece with a little slit that you can pry open. Remove the battery, pop that chamber open, and disconnect the cable and look for signs of damage or corrosion. If you clean the cable or no signs of damage are evident then you may need to replace the LCD/Digitizer.
If the issue happened after the unit was dropped then more or less it may have suffered damage and the digitizer is affected.
Good Luck
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
awabdehw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 1,965
