Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
20 Vragen Bekijk alle
iPod syncs then ejects 10 seconds later
I've had my iPod classic for two years and needless to say she goes EVERYWHERE with me. I've had no problems with her until recently. I sync my iPod to itunes and then a few seconds later it will automatically go into ejecting. I've uninstalled and re-installed itunes,I have the lastest version.. I've even restored my iPod. Please help me I'm going insane !!!!
Is dit een goede vraag?
Score 2
1 Opmerking
Have you started using an usb-hub lately?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
i've read a few things. maybe this would help:
start itunes, go to "Edit" -> "Preferences" shwitch to the "Devices" tab. and toggle "check on and off" the disable automatic syncing feature, this should fix the problem.
but normally it would be enough to change the settings from automatic to manual on the "top page" for the iPod - i always use the manual sync on my iPods - the method above is more for the people who were plagued by a fast "3 second sync"
Was dit antwoord nuttig?
Score 5
1 Opmerking:
what if there is not a toggle option ?
door
I had the same connect/eject issue
The issue for me was that the ipod was almost out of power.
Once I charged it up using a wall charger it connected fine
This was after testing usb ports, swapping cables, etc....last resort was to power it up
Problem solved
Score 1
1 Opmerking:
door
Voeg je antwoord toe
breakdown69s zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 78
Altijd: 20,917
