Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
No sound - no sound devices found, audio through USB working
After water spil the logicboard is cleaned by ultrasonic cleaner.
Keyboard replaced.
All is working OK except audio.
In the settings no output and no input devices found.
Connecting a Bluetooth headset audio is OK
Connecting a USB headset audio is OK
Connecting Airplay audio is OK
only no Speakers and no Mic
what could be the next step ??
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
At this point I would expect the audio logic on the logic board is damaged. Double check by plugging in an external speaker in the phono outlet. If that is likewise dead.
If the phono outlet is working then you'll need to check your speaker & microphone connections on the logic board.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Phone outlet is not working.
I think it is time to measure all voltages and signals around the audio IC.
door
Measuring all voltages around the audio chip made me decide to change the audio chip.
Removed the old one and placed a new chip.
Now the audio is 100% Good !
door
If this answer answered your question please remember to rate (score) and mark it accepted.
door
Voeg je antwoord toe
Rene zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 175
