Water damage, dried everything, battery refuses to charge
I have a 2013 11" MBA that had a water damage incident. Water (actually, monster energy drink) spilled inside of a bag with a MBA that was placed charger side down.
I took the mba entirely apart down to the keyboard, after which I cleaned it with deionized water, dried it out with compressed air. I let it dry a bit more before restarting. I don't think there is any more water that I can dry.
Currently, the macbook runs great...on adapter power. It also will run fine on battery power.
However, it will NOT charge the battery through the adapter.
I have done an SMC reset, and PRAM/NVRAM reset.
I believe there is damage to one of the boards but I am not sure which one - the small I/O board or the main logic board.
Does anyone have any suggestions?
Thank you.
Is dit een goede vraag?
2 opmerkingen
Did you completely remove the logic board to clean it? There is more components on the other side as well that likely need cleaning.
door Dan
Yes, I was able to remove the logic board as well as the smaller IO board to clean/dry them.
door brown doc
