Ga door naar hoofdinhoud
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Vragen Bekijk alle
How many CCFL tubes in 30" display
Wondering if somebody can tell me how many CCFL's there are in the Cinema 30 inch display.
Also, if you've have taken one apart, how long are the CCFL's and what diameter?
I'm trying to find some replacements.
Thanks
Is dit een goede vraag?
Score 7
4 opmerkingen
Hi,
Did you ever find a solution? Could you share if so?
I have two that I would like to fix.
Thanks
door
Hi,
many thanks for asking. well it was a other problem. the CCFL's are not damaged. the line driver are defective.
door
oh, thank you for letting me know...it seems you had luck in fixing it, I hope I will be able to do the same.
door
I have two 30" displays and they are both showing dimming and yellowing with age but are otherwise perfect. Would replacing the CCFL's help? Does anyone know where I should look to find out?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Here's one of the last sources I know of for CCFL's: LCD Parts.Net.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
I think there are totally 16 CCFLs distributed horizontally & evenly at the back of the LCD. I don't know exactly how long they are, but they are at least as long as the width of the screen, so the illumination could be even.
I've been wondering why there is so little information about the aluminum displays (A1081, A1082, A1083). I'm pretty sure there are still many being used, and some may need attendance. Maybe ifixit.com could show some instructions on this.
Score 5
Voeg je antwoord toe
Mark Ellis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 3,889
