Ga door naar hoofdinhoud
The Nokia Lumia 720 is a Windows Phone 8 device manufactured by Nokia. It was released in April 2013.
24 Vragen Bekijk alle
Vraag afgerond
Can a Piece of Nokia Lumia 720 's motherboard can be fixed?
A little piece from the motherboard of the nokia lumia 720 that is used to connect the camera and volume flex to the motherboard came off and now i am not able to connect them and therefore turn on my phone anymore, is there any way the piece can be replaced so that i do not have to buy the whole motherboard. Is there any way i can get my pictures back? it should be a piece like this https://d3nevzfk7ii3be.cloudfront.net/ig...
Is dit een goede vraag?
4 opmerkingen:
i do not have the piece that goes there. could i buy it somewhere or do i have to take it to a professional so that they fix my motherboard? if it can be fixed...
door
It will require microsoldering and you will have to source the connector
door
if a take it somewhere to fix it will that be expensive?! and will it take long?
door
please can you help me out oldturkey03?? im just not sure if i can fix it alone
door
Voeg een opmerking toe
1 Antwoord
I have the same problem. Local repair shops denied servicing - as they don't have the connector. Authorised service centre (Level-2) doesn't have facility and connector to do that. They will collect the phone, send to Level-3 service centre (only in Bangalore in India). Time and money (~ INR3500.00) - both required are high.
I am still left with no good solution. Help me if you have any better solution than sending to L3 service centre.
-Sanjoy
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,093
