Ga door naar hoofdinhoud
The Blu Dash 5.0 Dual SIM D410 was released September 3 2013. Repairing this device is relatively complex and requires tools that have to be purchased.
70 Vragen Bekijk alle
phone is coming on and staying on "BLU" ,how to fix it?
my phone is coming on and the screen is staying on the word "BLU" and not coming on fully
Is dit een goede vraag?
Score 34
1 Opmerking
How to solve this problem
door
Voeg een opmerking toe
10 Antwoorden
Het nuttigste antwoord
i'm having the same problem.. but when factory reset and restart it.. the problem do not change :-(
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
i tried that method but it still didnt work..what other options do i have or what do you recommend?
door
Did u wipe the catch partition in the recovery? If not then try that. And if still that didnt help out. Then u may need to flash the phone. Look in here for answers on how to http://forum.xda-developers.com/android/...
door
i did it and phone not working
door
you have to boot into recovery and wipe data or factory reset..
remove the battery and wait for some seconds then insert the battery again
hold volume down and power button together until u see a recovery menu, then choose wipe data/factory reset us volume down/up to navigate .. then restart when done..
WARNING!personal data Like SMS/MMS/Contacts/Apps/call history .... will be gone for good if you need those then consider taking the phone a pro for backup..
Media such us pictures/videos/musics will not be affected
Score 1
5 opmerkingen:
I tried that but the same thing is still happening!!!!!!
door
i tried that but the same thing is happening
door
Did your phone ever started working properly. Again. Guys??
door
its the same thing happening ugggggggggh
door
can you help me how to update the software
door
Have your tried booting in safe mode? A safe mode can help you to diagnise and uninstall the culprit app causing your mobile to stuck on boot screen. Safe mode can also help you to detect if there is any hardware or software issue on the mobile.
  • Power off your mobile
  • Hold the Volume Up+Power key together
  • Release the power buttom once you see the logo on the screen.(keep the volume key holding)
This will boot your Mobile in safe mode. Unistall any recent install app which you think migh cause the error.
Follow the detailed guide here: Android Safe Mode, What is Safe Mode? How to Use it to diagnose the Android problem.
Score 1
1 Opmerking:
Thanks for the answer @somnio360. The guide was helpful and worked for me
door
I had the Blu 4.0 star, and the brand itself is pretty bad :/ its a cheap brand, and I had that problem, and exchanged it, and the problem came up again :/ factory reset worked for a while, but it is a problem that will happened again and again. I would suggest a new phone.
yesnmk,l.;/""""""""nxdc nm b .n
use volume down/up to navigate and power button to select.
Did you get your phone fixed?? If so what did you do?? Im having the same issues with my Blu 7.0
Sim kit not in stole
Update (12/15/2015)
Here is a solution..
I had the same problem and i had to send it in. no reset would work. good luck
Voeg je antwoord toe
amanda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,059
