Ga door naar hoofdinhoud
The Keurig B77 Coffee Maker is a single-cup coffee maker made by the Keurig company.
12 Vragen Bekijk alle
Unit will not turn on
Unit suddenly will not function after working fine 1 hour ago. The touch button to turn the unit on will not light up and their is no display on the screen
Is dit een goede vraag?
Score 18
1 Opmerking:
We have a problem about the same. Our power company installed a new transformer on our line and the unit worked prior to that then nothing we've tested the outlet and it's fine. Can we re-boot the unit?
door
Voeg een opmerking toe
4 Antwoorden
no power to unit whats up ? is there i fuse somewhere
Was dit antwoord nuttig?
I have the same problem, just got this coffee maker. Worked fine for a day, then it started acting weird. It wouldn't brew every time I pressed the button. Then all the sudden it stopped working and the screen wouldn't come on. Ridiculous!
1 Opmerking:
I'm having the same issue. My unit is a couple years old. Where can I take it to be repaired? Is it completely kaput or repairable?
door
Defective on-off switch
1 Opmerking:
how do I fix that ?
door
My keurig coffee maker will not turn on anymore . I had just used it to make a cup of coffee ,for the next one it would not start.
Voeg je antwoord toe
Neil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 25
Altijd: 3,214
