Ga door naar hoofdinhoud
Hoe je je werktuigen repareert, zodat je ze kan gebruiken om andere reparaties uit te voeren.
2233 Vragen Bekijk alle
Vraag afgerond
Some one using TI EV2300 to program/hack a Battery back
TI EV2300 is a tool to program BQ series battery gauge.
I'm considering to get my A1185 out of "Permanent Failure" using EV2300.
Some one ever tried that or have some info/suggestion?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
did you check the lipo cells first? are the fuses ok? - if a battery fails - it's most likely the problem of the cells and not the pcb inside the battery
so checking the voltage of every single cell and their fuses would be my first step - but that involves disassembling the battery (be careful and don't bent the cells)
Was dit antwoord nuttig?
1 Opmerking:
'cause i'll replace the cells and the g**d*** "self destructive" fuse. and i know what i'm doing.
just need some tool to reset BQ20Z80 status.
i don't know if this can be done by just programming SMBus...
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,785
