Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Vragen Bekijk alle
Vraag afgerond
Touch screen wont move, even after replacement
I have replaced a display in a iPhone 4, and a couple of weeks later the touch started messing up (not recognising any touch), for small periods of time. Now the iPhone wont budge at all. Have tried several new screen to rule out bad displays.
Could it just be time to call it dead as it is an older phone?
Is dit een goede vraag?
4 opmerkingen
I am currently doing a restore.. Will report back
door
Restore did not help.
door
hard reset? Also try some compressed air over the connectors and have a real good look if the connectors aren't damaged.
door
The LCD connector did slightly indicate some water-damage. It had that white residue (dont know the english word??) around it but nothing was near the digitizer connector. Cleaned it of but no luck.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Something similar happened to me but I later found out that the phone was exposed to liquid (albeit briefly). Another instance was I somehow broke off a microscopic piece on the logic board. Get a really strong magnifier and look at the logic board to make sure no jumpers,etc.have broken off. If you see something missing/damaged, it'll need to be microsoldered back on. Also look at the digitizer connection on the logic board to make sure any of the pins haven't been bent or broken.
Age of the phone doesn't necessarily doom the phone, just the condition of it.
Good luck and I hope I helped.
Was dit antwoord nuttig?
1 Opmerking:
I could see that the bottom speaker had previously been replaced (it had some sort of stamp on it), but otherwise I was not able to see any other damage to the board. Tried as well as i could to inspect and compare with another board.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 284
