Ga door naar hoofdinhoud
Released in February 2012. Model number: DSC-H55.
5 Vragen Bekijk alle
Is there any way to change my camera to a different color?
I received this camera as a gift from my grandmother. Unfortunately, so did my other three cousins. I want to make my camera look different than theirs. Is there any way I can possible change the color of the shell of my camera?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Yes, it is possible to change your camera to a different color! First i am assuming that you're interested in changing the black factory housing (outer shell) of the camera. To do this you will need to follow a few simple steps. First to complete this task you will need a Philips head screwdriver and a plastic wedge or splitting tool. Ok, now you want to turn the camera over and remove the three screws holding the bottom plate. Now remove the two screws on the right side of the camera, make sure to keep these 5 screws in a safe spot to be sure not to lose them. These 5 screws are all the same size so they do not have to be put in the respected spot which taken from, any five of the spots will work. Next open the battery compartment and slide your splitting tool between the crevice of the back shell around the screen until you are able to pull it off. Next remove the left face and there should be two more screw that need to be removed so that the front shell can be removed. Once this step is complete replace the front face with the one of your desired color, and screw back in the screws which hold the front shell. Replace the left wall with the new color by sliding it into place. Now put your new back face on around the lcd screen and bottom plate in place. Screw in the bottom three screws and the two which go on the right side of the camera. You now have a new color camera to stand out from your cousins, congratulations!!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Vanessa Forero zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 638
