Ga door naar hoofdinhoud
Repair and disassembly guides for garage door openers.
16 Vragen Bekijk alle
remote opener works close up - but no range
T/S progress so far:
New battery and several different remote control - same result
- can control with wall switch but remote more than two feet away does not work - works within one to two feet.
- suspect receiver circuit in opener - maybe front end not working.
can't find schematics to get in deeper and replace failed component. Any help appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check your drive unit (on the ceiling). See if there is a small wire hanging down from it. That is the receiver's antenna. If the wire is there, be sure it is attached. Some models don't have an exposed antenna. http://ep.yimg.com/ty/cdn/linear-access-...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
patrickmoretti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 189
