Ga door naar hoofdinhoud
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
30 Vragen Bekijk alle
How do I get my nooks charging port fixed?
when I plug my charger in my nook it does not work. I have bought a new charger and that's not that problem its the charging port.
Is dit een goede vraag?
Score 10
1 Opmerking
I have the same problem. When plugged in, the light turns green briefly like it used to, then orange. And then goes out and refused to charge. Now what do I do?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Yes, I found a used nook @ yard sale. B4 tearing down the yard sale nook, I √ to make sure it was going to charge 1st. Then I removed the port from that one & replaced my bad port. Take ur time & be very very careful. I found an online video to break down my nook. Power99 had a good video on youtube. Its been so long ago I don't remember if I used a small piece of electrical tape or a dot of electronics glue to hold it in place as I had no way to sauder it back. Works fine now.
Tools:
**Tweezers w/curved tips to grip the port 4 removal & replacement.
**T5 or T6 magnetic screwdriver
**Flat plastic pry tool w/ a smooth rounded tip NOT a fingernail file!!
**Tape or magnet to hold the 22 screws from the frame of ur nook.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
There was a small piece of metal that came out of the charging port on my Nook. That is why mine won’t charge. Does anyone know how I can fix this?
door
I have same problem
door
Voeg je antwoord toe
Alexis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 3,209
