Ga door naar hoofdinhoud
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Vragen Bekijk alle
Flickering screen when starting the smartphone
Flickering screen when starting the smartphone, then the screen goes off. Apparently smartphone presents normal operation although the screen does not turn more after starting the system.
Changing the Motherboard Flex Cable Ribbon I fix this?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Your problem was caused by damaged LCD screen, not the motherboard flex ribbon. Replace a new LCD screen can solve it. The tutorial guide is here: Disassembling Nokia Lumia 920 and the part is here: http://www.etradesupply.com/oem-nokia-lu... Good luck.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Ok Mia, thanks very much. I will try here and give a feedback.
door
Today I replace a new LCD screen and the problem persists...
door
Voeg je antwoord toe
vinnywebmaster zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 327
