Ga door naar hoofdinhoud
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Vragen Bekijk alle
My iPad 2 volume , power button not working
Hey I change the digitizer on my iPad 2 then power and volume nothing was working , So I had to connect it to the pc and reset it ,I replace the control harness and still not working then I change the power supply board and still not working , plus it doesn't lock with the case , I have no idea what else to do , help
william, 1 minute ago
Is dit een goede vraag?
Score -1
2 opmerkingen
Thanx it is well connected, but I'll double check , so getting a better cable mean buying it on Apple store ?
door
Apple Store doesn't sell parts for repairing your device. iFixit sells quality repair parts but you are paying a little extra for them. Other users may be able to chime in with other options.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Maybe it's a defective replacement power/volume ribbon cable or it was damaged during installation. They are very delicate. You may want to try a higher quality cable as the cheaper ones don't seem to work with the auto lock function (as has been my experience).
Was dit antwoord nuttig?
2 opmerkingen:
I may add that you have to be sure that the new Power-Mute-Volume cable that you installed is properly seated and connected to the board, and the big interconnect cable (the one that looks like the display/LCD cable) is also properly seated.
All the problems you are referring seem to be due to a defective Power-Mute-Volume cable like Brian says.
door
Thank you , yea I'll double check , where can I get a better parts , Apple store only ?
door
Voeg je antwoord toe
william zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 942
