Ga door naar hoofdinhoud
Reparatiehandleiding voor alle toetsenborden behalve die van Apple.
How to repair charging port?
When I last went to plug in my micro USB charger into my Zagg universal Bluetooth keyboard, the charging port was pushed further back into the keyboard. How do I take it apart to repair this device? There are no visible screws anywhere.
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
I just took mine apart. Use a heat gun to soften the adhesive, and slowly remove the rubber, then the case will seprate. The mirco USB connector is weak, and I have had several fail already. this part would otherwise be easy to replace, as it clips on, but Zagg will not sell the part. I may try to bypass the port, and charge directly to the battery...
Was dit antwoord nuttig?
Score 1
Not sure if this will help but here it goes. The connection was very loose and cable would fall out. The port was not loose, just seated far back. I took a file and filed down the cable plastic on the connector so it angled properly in relation to the case and port. Problem solved.
Score 1
Bought a new keyboard after mi puts roba
it broke off during normal use plus the wand has stopped working
1 Opmerking:
were do i buy new keyboard and wand
door
Voeg je antwoord toe
Lucas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 64
Altijd: 5,504
