Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Vraag afgerond
Data transfer from external hard drive to a new internal hardrive?
So I have followed this sites steps in data transfer to my new hard drive from the external one so I can replace the dead internal hard drive. But when I replace the internal hard drive it will still give me the question mark folder. I am not sure what to do from here. Do I need to back up the new hard drive with time machine and do a recovery when I start it? Or is there a way I can change the start up location back to the internal hard drive place? I am lost. Any help is appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
OK, still using your original HD in the external case you should be able to boot up your system. Now go into the System Preferences The fourth grouping you should see a drive Icon labeled Startup Disk. Open it up there you will see your two drives click on the now internal drive (blessing it). Restarting the system should then switch the startup to the new drive (don't forget to pull your external drive when you hear the Bong).
OK, you don't see the new drive! Now what? If that is the case the OS files are not properly installed. You'll need to download the OS installer from the Apple Store using your external drive. Once you down load it, run the installer just make sure you don't format your drive! It will walk you though the install process and should bless the drive as well.
Was dit antwoord nuttig?
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 262
