Can I replace the cuffs on my Patagonia DAS Parka?
I find the elastic cuffs on the DAS Parka too tight, is there a safe way to make them wider or adjustable? Is this something that I should send to a tailor?
Is dit een goede vraag?
Yes, you can widen them, but it might be a bit tricky. You will need to buy some longer elastic of the same width. The process will be similar to the drawstring guide we have listed here: How to fix an unthreaded drawstring
It may be difficult to get inside the section of the cuff that has the elastic, which could require some stitch ripping around the cuff. Be careful, as it is easy to tear the fabric.
If you need further help, contact Patagonia customer service.
Good luck and let us know how it goes!
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 554
