Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Five keys have stopped responding—must I replace the top case?
Hi folks!
Five keys (F4, 4, R, F, and ]) on my mid-2012 15" Macbook Pro have recently stopped responding. "E" has been giving me trouble on and off, but currently it's working.
Is there anything to do but replace the entire top case?
They went out slowly, at first, and then all at once: the "E" started responding intermittently in November. In December, sometimes my "F" wouldn't respond.
Last week, I removed and cleaned under "F," "R," and "E," blowing out dust and gently scraping around the little rubber pad under the keys. They all worked for a couple of days. Then this afternoon, in the middle of a paragraph, F4, 4, R, F, and ] (mostly in a column, except for the odd man right bracket) all suddenly gave up the ghost.
Now, when I take the keycaps off, pressing on the little rubber pad doesn't register in Keyboard Viewer. I've tried blowing them out again, but no cigar.
For what it's worth, I've also tried a restart, flashing the PRAM, removing and replugging all my USB/Thunderbolt devices, and Mouse Keys is NOT enabled.
So again: Am I doomed to an external keyboard or a $400 top case replacement? Or is there any other option?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sorry, sounds like something spilled into the membrane section so your wetting of the parts managed to liquify the junk and then it dried backup again.
Time for a new upper case assembly or if you are brave you could try taking it apart and try cleaning it from the back side. Just be ready to order a new case though, as you only have about a 10% chance here of success.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Elizabeth Chamberlain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 280
