Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Can I upgrade my I Mac 27" Retina 5k Graphic Card?
Greetings
After long Research i want asking to how change my iMac Intel 27" Retina 5k Graphic Card and upgrade it to be nvidia Quadro K4100M or nvidia Quadro K5100M .
i want know about it cause that kind of nvidia Quadro working on notebook and All-In-One Workstations .
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No You can only use a GPU that was used by Apple As OEM so if you had an AMD Radeon R9 M290X graphics processor with 2 GB of dedicated GDDR5 memory you could put in an AMD Radeon R9 M295X with 4 GB of dedicated GDDR5 memory if you could find one at a reasonable price. Also selling your old card wouldn't be too profitable as only someone with a damaged card would be a potential buyer. The machines are so new a damaged GPU should be a warranty repair .
You'll have EFI (aka bios) and extension (aka driver) if you attempt to put just any old GPU in any Apple computer.
If this answer is acceptable please remember to return and mark it accepted.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Greetings machead3
thank you so much for your answer ...if i asking apple web site to making special performance ?
i found strong performance in ebay ... i only need Nvidia Quadro K5100M on this performance ? is that possible in apple web site ?
Workmanship: 1 Year
Brand: Apple
Product Family: iMac Late 2014
Screen Size: 27" Retina 5K (5120x2880) LED-Backlit IPS Display
Memory: 32 GB (Maximum installed)
Hard Drive Capacity: 2TB FLASH/SSD (2000GB total)
Processor Type: Intel i7 Quad Core Haswell
Processor Speed: 4.0 GHz
Video Graphics Processor: AMD Radeon R9 M295X 4GB GDDR5
802.11ac/a/b/g/n Wi-Fi, Bluetooth 4.0
Thunderbolt, USB 3.0, SDXC Card Reader
720p FaceTime HD Camera, Dual Mics
Mac OS X Yosemite 10.10.1 (64 bit)
door
The AMD Radeon R9 is the best performing GPU for your machine. For other machines/GPUS see this site.
door
But, what about putting in it a GPU from a 2017 Model like Pro 580 ? Wouldn‘t it be a good solution for every 5K iMac user instead of buying the brandnew 2017 5K?
door
“You'll have EFI (aka bios) and extension (aka driver) if you attempt to put just any old GPU in any Apple computer.”
I’m not tracking here. Are you saying there will be issues with the efi and extension? This process isn’t plug and play?
Also, I’m looking at a machine with the 2048 MB AMD Radeon R9 M380. Is the 390 the only upgrade option? Thanks for the help!
door
Voeg je antwoord toe
cuteboytop2010 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 28,333
