Ga door naar hoofdinhoud
Portable and simple laptop released on April 2007 by Hewlett-Packard.
How easy is it to swap the wifi card?
hello,
this isnt repair related yet but long and short i am buying a hp mini 311 either entirley stock if the wireless is easily upgraded
if its hard i am going for it configured
RAM and HDD can be upgraded if needed
CPU is fine for a netbook
how hard is it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
it should be no problem for you
here is a link to a teardown and some wwan experiments ;-)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Are you planning to make a hackintosh out of it ? or why do you want to change it ?
door
ok, compatible isn't the issue - we are talking about a windows machine - you can also use the mini pcie wifi card from a MacBook and i could bet that the cheap dell wifi/wwan/br stuff will also work in this unit
door
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 2,963
