Ga door naar hoofdinhoud
Repair information and troubleshooting for the Dell Latitude E6230 business class laptop computer. This laptop has a 12.5 inch screen, and was announced in May 2012.
15 Vragen Bekijk alle
Laptop freezes after waking from hibernation or sleep?
for the past few days, when i wake up my computer from sleep and hibernation mode it'll freeze and the only way tp get it to work is to hold the power button.
just for your information, i recently updated some drivers but i will try to delete the new power management driver and go back to the old one
Edit: i cannot roll down battery driver for some reason
Is dit een goede vraag?
Score 43
75 opmerkingen
Brothers , just go to
1. "Device Manager"
2. "Storage controllers"
3 . Right click on "O2Micro Integrated MMC/SD controller" and disable this driver.
Your Welcome!
door
Thanks alot brother (Y)
door
I was having the same issues with my Dell latitude 5420... But with the steps above I was able to stop it... Thanks Alot...
door
me too, same issue with Latitude E6430 and the above steps solve it. Thank u very much
door
Wow...Thank U Thank U it worked for me
door
70 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
It's one of the card readers, just disabling it fixed the issue for me
Was dit antwoord nuttig?
Score 9
9 opmerkingen:
what is the card reader?
door
thanks much bro... you made my day and I have solved the problem which bothered me almost two months ..I changed the window almost thrice times but the problem still existed till today i got ur help...thanks much...
door
1. "Device Manager"
Your Welcome!
door
Thnx bro, worked for me also
door
Thanks a lot bro i too resolved by this problem
door
4 commentaren meer tonen
1. "Device Manager"
Your Welcome!
Score 3
2 opmerkingen:
Zabihullah Xabih  thank you. In my computer I have not option “O2Micro Integrated MMC/SD controller”, but I check another similar things. In my computer (M4800) the problem is option “ ControlVault decive”. Click on it and choose “Disable”. And computer works perfectly (without freezes after waking). Thank You! You helped me to find solution! :)
door
Even I changed the OS from Windows to Ubuntu and CentOS but still I’m getting the same issue and many of the users are complaining the same thing on Dell E7490. It seems some hardware issue not OS issue If we lock (Win+L) the system It's happening Hence, we are turning of the monitor instead of it. Any solutions would be appreciated. Thanks in advance!
door
Same issue here (caused by the Dell O2 card reader driver A04).
Edit: the A02 revision of the above driver causes the same issue.
This issue occurs in Windows 7, 8, and 10.
I fixed it by uninstalling the Dell O2 card reader driver Rev A04 and then installing the Lenovo equivalent driver from here:
http://support.lenovo.com/gb/en/download...
This covers Dell Models
E5530
E6430
E6530
And probably any other Dell laptops with the O2 card reader driver.
Score 2
This is indeed an O2 Micro driver problem. Delete it from Device Manager. It will ask if you want to delete drivers, and say yes. Rescan for hardware change, and let Windows 10 install default SD card reader drivers. This will allow you to still use the SD card reader and put the laptop to sleep without issues.
Score 2
Reinstall OS it help me with freezing while going to sleep
Voeg je antwoord toe
V_S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 35
Altijd: 51,609
