Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
New replacement MacBook Pro battery discharging erratically
Hello,
I've just installed a replacement battery (bought from iFixit) for my mid-2012 MacBook Pro 13inch Unibody.
The battery charges up to 84% then jumps to 100%. On disconnecting power lead battery holds 100% for a minute then jumps back down to 84%.
I've done an SMC reset. No difference.
coconutBattery shows the jump in current charge from 5712mAh (fully charged) to 4784mAh (tried uploading images but get a resolution error).
Is this a dud battery. Do I need a replacement from iFixit?
thanks
Mark
Update
January 23, 2015
I'll accept @mayer's answer. After several days testing my MacBookPro *seems* to be performing normally. The replacement battery seems to be ok. However I do have some reservations.
So to recap I reinstalled OSX Mavericks using latest combo update. Did SMC and PRAM reset then did two discharge-recharge cycles. I'm now getting 5-6 hours from a full battery with low-medium use. Time remaining and estimated time to full is generally ok - at least there aren't any big jumps from say 50% to 100% or crashes from 50% to zero.
I'm still getting the impression though that OSX doesn't have a perfect handle on how much charge is on the battery and neither is coconutBattery. Occasionally the machine won't reboot after being down to ~30% charge but I'm not sure whether this is because of heavy apps that OSX is trying to reload after previous shutdown. Sleep seems ok and isn;t drastically draining battery.
As a rule of thumb how much charge can I expect to see lost during periods of x-amount of sleep (say overnight) or from shutdown to reboot (say overnight)?
As a further query the design capacity value from coconutBattery jumps from ~85% to ~96% between and during periods of recharge. Is this normal?
thanks all
Mark
Is dit een goede vraag?
Score 3
2 opmerkingen
What was happening with the old battery?
door
Had service warning on old battery
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You may need to reinstall your system and/or update your firmware. Here's an excellent question on the problem: Erratic "Battery Charging /Not charging"
UPDATE
put the old battery back in, run Coconut Battery and post your results. Tell us if the battery gives you a red or black X.
Was dit antwoord nuttig?
Score 1
6 opmerkingen:
OK thanks. I'll try PRAM reset and SMC reset again, then complete discharge/recharge cycles and see what the result is.
door
I'll reinstall old battery and post coconut results if my first attempted solutions don't work.
door
@mayer - Went through 1 full discharge/recharge cycle. Following this the battery discharged as expected from 100% without any jumps. However, MacBookPro on standby still drained battery as though awake. I then performed an SMC reset and PRAM reset. Battery use now *seems* to be functioning normally.
Thanks for your help
One further question. On coconutBattery the design capacity reading has jumped from 99% (first start-up after battery install), to 96% (after discharge/charge cycle), to 97.3% (after SMC/PRAm reset), to 96.3% (after a test period of sleep). Is this significant? OSX Battery status still good, operating temperature 25.6degC, discharging 12 Watts at current low usage.
door
wait. Still not good. Crashed 100% to 50% just now. hmmm
door
You accepted my answer, did the problem rectify itself?
door
1 commentaar meer tonen
Voeg je antwoord toe
mruddy73 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,352
