Ga door naar hoofdinhoud
The HTC Desire 310 is a dual-SIM Android-based smartphone designed and manufactured by HTC.
10 Vragen Bekijk alle
Vraag afgerond
How to replace the motherboard?
Hi,
My son's HTC Desire 310 stopped working..no power, no sign of life. A repair shop said it is the motherboard. How do identify which motherboard to search for? I have found some photo tutorials online that I hope will guide me. Total amateur here, but needs must:)
Paul
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi Paul,
Did they say what was specifically wrong with your motherboard? If you go the route of getting another motherboard, do note that this is the phone itself and you will not retain anything not backed up to the cloud.
When searching for the motherboard, you will most likely find pull-offs that are, of course, used. Check to make sure it is the same model, and also that it is for the same carrier you are using.
Just curious though, what prompted this issue? Was there any physical damage involved?
Was dit antwoord nuttig?
Score 1
The issue was that the mobile fall in water
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,333
