How do I replace the keyboard?
How do I replace the keyboard on my laptop? I know that there is a tear on the left shift key pad that I found after removing the key to clean a sticky substance that I thought was the issue.
Is dit een goede vraag?
Hi Hurley,
As far as i know with the knowledge of the same model but from Packard Bell this laptop has sort of a "unibody" like a macbook.
U would have to remove the complete top cover by removing the screws sitting at the bottom and lift the top cover up as a whole to get to the keyboard.
Mind you that most of the times these top covers are extra mounted with clips so it might take a bit of effort to remove it. I would suggest to start from the front (the side of the touchpad) and move forward towards the back.
Hope this helps you in any way.
Was dit antwoord nuttig?
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 1,512
how would ou clean under the trackpad on this laptop? i have the same one and im wondering cause i need to clean mine
door sabrina payne Deel
