Wifi Problems with Same Parts, but Different Shell
Here is an interesting problem that is really baffling me.
I use the same parts for the components for the wifi/webcam that is on a MacBook Pro (Wires and all), but when I place them in a different display shell it doesn't work, but when placed back in the original shell it does.
Swapped shells because the old one was damaged and had one in decent shape laying around.
Any suggestions?
Is dit een goede vraag?
3 opmerkingen
Might be a silly question but did you verify the new shell had the correct drivers? are you only replacing the shell and nothing else? such as motherboard, HDD ect.
door Goulithum
Like I said, all I swapped out was the top half and I took all the wires, cards, and LCD Screen and placed them in the new shell.
So all the parts should be fine. That's where I'm confused.
door Kenneth Curtis
The guys are the same, just moved. The shell was from another MacBook of the same size, but since the guts were a 2011 MacBook parts, I took those out and put the 2009 guts in. His includes the iSight board, airport, blue tooth, all that and the wires. So logically this shouldn't be happening.
door Kenneth Curtis
