Ga door naar hoofdinhoud
De Microsoft Surface RT (model 1516) is de eerste tablet die door Microsoft is uitgegeven. De tablet werkt op Windows RT, deze versie is speciaal ontworpen om te werken op een tablet. Om deze tablet te repareren heb je schroevendraaiers nodig, alsook gereedschap om hem te openen.
128 Vragen Bekijk alle
My zif connecter on the motherboard, for the power ribbon, broke.
Was plugging in power ribbon to zif connector on motherboard when it (the ziff connector) broke off the motherboard. How can I get this fixed or is it bye-bye motherboard?
Is dit een goede vraag?
Score 6
1 Opmerking
Can you please upload a picture?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
this is what my tablet looks Like without the ZIF connector,
and the other picture is of the connector actually broken.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I'm in the same boat. Connector broke exactly the same way. Any luck? Also, I don't have the charging cable on hand (repairing for a friend, they had no clue what they were doing), is it possible to power the tablet on using AC power alone?
door
Same issue anyone get and answer? I noticed on the pic of new mobo it doesn't have the connector on it D:
door
wher to buy that connector
door
ny jumpering on board will be appericiated?
That Zif connector just holds the ribbon cable in contact with pins. You can try cutting off a sliver of plastic from a credit card and wedging it in there to hold the ribbon to the connector. I have done this with my laptop when the zif socket for my keypad broke. It takes a very thin piece to do so. Then take some captons tape or other electrical tape and place it over the socket to ensure it stays.
Voeg je antwoord toe
thomaslloydphippin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 893
