Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
How many chips do I need?
I have a late 2008 13" Unibody Aluminum Macbook with 2GB of memory installed (2x1GB). If I want to upgrade to a total of 4GB, do I need to buy 2x2GB chips or can I just buy one 4GB chip? I'm sorry if this is a silly question, but I'm pretty new to all this. Thanks in advance.
Is dit een goede vraag?
Score 1
1 Opmerking
I purchased two 4GB RAM chips and just installed them today. So happy I did. Now when I view the "Activity Monitor" I see that I have plenty of RAM doing the activities I normally do. Thanks again.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Originally, this model was only unofficially capable of stably supporting 6 GB of RAM (one of your current chips and a 4GB chip) , but as confirmed by OWC, it is capable of supporting 8 GB of RAM (I'd get two new 4GB chips) if updated to Boot ROM Version MB51.007D.B03 and running MacOS X 10.6 "Snow Leopard" or higher
If this answer is acceptable please remember to return and mark it accepted.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thank you. I have Yosemite running on it now. What is Boot ROM Version... Sorry, I'm a novice. Also, why did Apple say they only Support up to four gigs when the comp can handle eight?
door
Apple has a page explaining the Boot ROM (or EFI firmware) versions here: http://support.apple.com/en-us/HT201518
Apparently they released this update to fix a noise problem, but it also allowed the model to handle more RAM - Apple just didn't want to publicize it.
Also, be careful what you buy (see this discussion: https://discussions.apple.com/thread/461...). I have one of these MacBooks too - there are no silly questions.
door
Thanks so much. I appreciate this. So, if I did not do this particular update, I would still be ok to run 4GB of RAM it sounds like. I know I could go up to 8, but I'm happy going from 2 to 4 for now. Especially since we don't do that much on it. But it would be nice to have a little bit faster speed when utlizing multiple tasks on it.
door
The best performance boost you can get your machine for your money is to run MAX RAM (Top tier RAM not Cheap lower quality). Since you've pushed the OS to the MAX do yourself a favor and do the EFI update (It may have already been done as part of Yosemite) and as long as you're opening the box put in 2x4GB chips.
door
Voeg je antwoord toe
staceycee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 19
Altijd: 207
