Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Vraag afgerond
Why does my screen stay black during calls?
During a phone call my screen blacks out the way it should. When I lower the phone to end the call or look at the screen the screen does not light up. I'm not using a case that would block the proximity sensor. Is it likely the sensor has gone bad? And if so is it replaceable?
Is dit een goede vraag?
2 opmerkingen
Have you a screen protector on the front screen?
door
I did have a screen protector on the front. I revived it and am having the same issue.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
have you had a screen replacement at all? and yes it's replaceable, not a big problem at all (hopefully) :)
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Hey there,
Your screen or your proximity sensor could be defective. If not the proximity sensor could of gone bad from a drop. They are both replaceable, you can use your voice memo to test your proximity sensor by recording something and playing it back. Just put your finger over the proximity sensor and see if it blanks out or if they screen stays black.
I would recommend you take the device to an experienced shop. The iPhone 5S is very touching with the 64 bit operating system and your phone could be destroyed with one wrong move. I would also try connecting your device too itunes and updating your software. Apple has been having a lot of issues with their software. Hope this helps.
- Archie
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,426
