Ga door naar hoofdinhoud
The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0. Released in July 2013.
443 Vragen Bekijk alle
I cant on my tablet why?
in my tab the process of updating software was going on acciedently it was cancelled it kept on then off on and off for do much time then it stoped because i think the charge finished i kept it on charge but it shows a battery empty for the time i keep it on charge it doesnt respond
till then i cant on it should i only install a softwate or something else?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I'd start with a reset: reboot by pressing on Power Button and Home Button.
Once you see the start-up menu, choose "wipe cache" then if successful, choose to wipe/reset tablet.
If not successful, you should download a fresh version of the firmware, and install it using Odin.
Of course in both cases, all user data will be erased and lost unless you have a back-up.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
sama zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 56
